Sat Nav Intermittent Freezes
sakauk
E250 CDI BlueEff Avantgarde Auto
I got the new C Class (W205), The Sat Nav is the Garmin SD based one supplied with the car. The 2 usb slots and one SD slot is inside the little storage box between the seats.
Sometimes when i start the engine , the sat nav shows - "No Memory Card Containing navigation Software Inserted." and it stays there. When it happens it fails to recognize USB media as well - I keep one USB stick plugged in all the times for mp3 and i dont use the other usb slot. I don't meddle with these slots always they remain as it is closed in the box.
It looks like something happens to the center console where almost it cannot read from the external devices - SD, USB etc The console actually not freezes as i can still listen to Radio or use Bluetooth music etc.
When this happens there is no way to get the Sat Nav or USB Working. I tried taking SD card out and put back in, turn center console off and on, turn engine off get out of the car and keep it locked for about 5 mins - but none has worked.
However when i keep the car locked more than a few hours it seems to resolve and everything turns back to normal after this laspse.
This is a brand new car and I have only used it for 2 months and so far about 5 times this has happened. Last time when it happened I took it to the dealers workshop but by the time technician became available (after about an hours wait) it was all back to normal, and technician said there is no fault. I had taken a photograph on phone and i showed it to him but i think he wasn't convinced. Now i have recorded a video while it happened last time- i am going to take it to the technician.
Anyone had similar experiences please?
This only happened so far when the center console starts up , when I start the car to start a journey, so far it never happened while I was driving the car.
Thanks in Advance
Sak
I have had the same thing now I am told this could be one of 2 things either your due a telematics update which you probably are or the SD is corrupt and needs changing contact your dealership they know this is happening and should be able to deal with it
Anyone been able to install the mercedes Benz download manger tried both my Mac and PC with no luck I get further with my PC but then it tells me the installer file is corrupt ! Ideas?
