Sat nav
kennyc
Hi I have a 2011 nov 2011 c class coupe, can someone tell me which version of command I have? Or how to find out Cheers
If your Comand screen hides away when switched off it's NTG4. If it's permanently on display it's NTG4.5. Assuming you DO have Comand, not Audio 50/20!! You have to check the option codes via the VIN number - if they're not listed in the front of your owners manual, there's a thread on here specific to requests for options fitted via VIN number.
Upto model year 2011 is NTG4 from model year 2012 its NTG 4.5
Model year 2012 started appearing mid 2011.
Hi thanks, mine does not go inside dashboard when switch off, so am I correct in thinking its a 4.5 then, I will check manual to see if I can confirm that
Cheers
