SEC Wheel Hubs
Mblinko
UK
W212 E350 Estate
Does anyone know if there is a difference between SEC and SEL front wheel hubs. The previous owner of my SEC had the spigots machined to fit the modern after market wheels that were on it and now, even when using the wheel centring tool, I can't get them centred and have an imbalance at speed.
If they are the same and anyone has any, I'll likely buy them off you.
hubs are the same AFAIK. I recently had to replace rear hubs and took them from an SEL, same number back and front when I checked.
Thanks for the info. I've found a little engineering company to do some spigot rings for me.
126 Wheel wobble vibes
Well, went to engineering shop today and wheels and hubs measured, but hey are all standard and spigots not required. This good but what's causing my vibrations :dk: i daren't go over 60:( Wheels are well balanced. Alignment done on a new Hunter machine. The steering seems a little odd, it seemed to under steer going slowly round a mini roundabout and tramlines on the straight. It feels a little odd.
Anyone any ideas ?
Could be caster angle out, tracking ,camber out. Are these wheels bigger or smaller than what was on there before
Martin
