Unfortunately we are in the UKBlackC55 said:Its probably a faulty instrument cluster. Contact cartronix in waterlooville for repair.
Sorry I thought the place sounded AmericanAMGeed said:Cartronix are in the UK. Waterlooville is in Hampshire Instrument Cluster Repair - Speedometer repair - Cartronix
Vehicle is E55.carlbr said:Hi. Just had new command system fitted. Collected car today. Just noticed time is 5 mins slow And date is 2003. When I press system and press date The hours I can alter. The minutes only alter by 30 mins intervals. The date is greyed out. Do I set this on the instrument cluster and not on the command? Thankyou.
Hi.
And date is 2003.
Thankyou.
Hi
On the instrument cluster
It does not have clock.
In my manusl it shows clock and click settings.
But on the instruments cluster there is no clock or time!
Any ideas
Hi
Any ideas
Do you mean you can't get to the clock settings in the middle of the speedo? If so it does say you can only do it if you have the Audio 20 and specifically not the 50 or Comand, in my manual.
