brucemillar
- Nov 18, 2010
- C55 AMG Wagon - W124 300te 4matic Wagon - BMW 4.8is X5 E53 - SWB Pajero 3.5 V6 24v
Well after what seems like an age, my 124 returned home this afternoon. This after an extended 6 month holiday at Wright-Tech in Sidcup.
The length of time away was fine and agreed between myself and Andy before work started.
Work began (again) at last years BOTG when my engine bay OCD spotted a fine misting of hydraulic fluid that on investigation was shown to have dropped from the “hydraulic tandem pump”. This carries fluids for the power steering & 4-Matic system and is driven by a dirty great pulley. Fluid was dripping from behind the pulley down onto the main belt where it was misted and thrown in a perfect arc up over the front slam panel and inner wings.
When I say “dripping” I am talking about a dingle drop of fluid once every few hours. But enough to annoy the **** Out of me.
As is always the way these days. No refurb kit was available nor was a new tandem pump.
Once again to the rescue came the absolutely wonderful Simon Brown (Carat 3.6) who just so happened to have a good second hand pump. Deal done and Simon posted the pump off the Andy at Wright-Tech.
Next leak. Gear box pump main seal. It could have carried in for years but was also misting and spraying under the car. Guess who just happened to have a replacement ? Yup. Simon to the rescue again.
So with the two pumps on-site all Andy had to do was remove the engine & gearbox again (I think this is the third or fourth time) replace the pumps. Check the leaks. Do all the due diligence bits you do with the engine and box out including cleaning the engine bay (again) and the underside.
Then fix the sticking 4-Matic juddering issue. This turned out to be a mixture of leaks, poor pressure, sticky solenoids and needing another good bleeding.
And so she’s back. I drive her home from Sidcup to Stockbury and smiled the entire journey.
Driving. Set up 124 is just great fun really great fun. Boy did I enjoy that.
Now it’s back to cleaning and some fettling (needs a new thermostat).
But, it’s great to have her back home and looking, sounding and driving beautifully.
Fingers crossed.
Fingers crossed.
