car will pull forward in Drive when you are standing still, you apply footbrake to keep car stay in place.
there will be friction
I always put in N at redlight when it's the queue
my car always pulls forward in D when in stationary.
I don't always put it in Neutrale only on long waits at red light with the foot on the brake.
Yes it pulls, but if you do not allow it to actually move then there will be no wear. Think about it. It's the same as having your car parked on a steep slope...the tyres will not wear yet the static friction is much greater than when the car is parked on a level surface.
I have highlighted your sentence.
this is what I ment with wear on pads and rotors if you leave the gear lever in D while waiting long time at the redlight, car pulls forward and you have to apply footbrake standing still.
metal on metal must cause friction and wear mostly to pads coz discs are solid steel and don't wear as fast as pads.
pad compound is softer than disc.
therefore I many times put the stick in Neutrale also holding foot on brake, no pull forward no wear on pads
it won't cause any damage to transmission when I stand still and shift lever to N
But unless the car is actually moving there is no wear.
You apply the brakes to come to a stop and the parts are wearing, but when the car has fully stopped the wear also stops.
Am I misreading this?
