Hi there,
I have read a lot of talk about the leaking roof seals on the R230 SL causing issues with water ingress into the roof mechanism etc. My car seems fine in this department at present and the boot is dry as is the mechanism itself in the boot.
Is there any visual clue as to whether the seals have been done or not or is it not every one that needs doing, just luck of the draw?
If it is a good idea to change them then when funds allow should I do them as a preventative measure.... I know they are not cheap btw!
Any advice appreciated.
