SL350 Fuse information
Mercv8
UK
Anyone know where i can find the fuse infrmation sheet for a 2004 Sl350?
My mother in law has a stuck boot whenever she tries to open it electronically. It wont even open if you try and open from the handle. You need to use the key to open it - Which is a pain for anyone that knows about these cars..
The boot light is constantly on inside the car, and im thinking it may well be a fuse as her boot was leaking water a couple days ago before i sealed a broken seal with some silicone glue.
Honestly.. You cant beat old mercedes build quality.:rolleyes:
There is no fuse that will solve your problem
How do you know that the boot light is on all of the time
Its displayed on the drivers door. Where the boot swtich is. A little red light is illuminated - Not the light in the boot itself. So when pressing that switch the boot no longer opens.
Nor does it open when she tries to open it from her fob electronically.
OK I understand the light bit now.
The light being on show that the car does not recognize the boot lock, and I think that the fault must be on the boot lock itself
