Hi, can anyone offer a bit of advice please. The driver window on my SLK has developed a problem. To start with it sounded like the motor was running on after the window was opened or closed, but has now moved onto sometimes not working at all, after a few tries it will work, but continues to run on a little. When I closed it tonight, it didn't quite go all the way to the top with the first effort, but did when I moved it down and then back up. Does anyone think it is a motor issue, I'd rather order a new one before removing the door cover if it's likely to be the motor?
Thanks for any replies
