SLK Washer Bottle Issue
ramgee
slk200
Have 2006, SLK 200, windscreen water bottle leaking where the washer pump nozzle goes into the washer tank. I took it the pump out cleaned the area but it still leaks - any advice to fix it.
Instead of naming all your threads 'Mr' for some reason?
You will get more replies if you give your threads a helpful title, eg: SLK Washer Bottle.
I have changed it for you.
TITLE means Topic for reply or thread
But thank you for making my morning.
If its like a W203 there is a rubber o ring sort of washer around the hole.
