SLK250D R172 2015 CAMBER BOLTS
Pedrogsxr
Portugal
MERCEDES SLK 250D
Hi guys...ive been looking around and ive seen that some people advise FEBEST 1629-212-kit camber bolt...i bought and i cant find a way to fit...ive been looking everywhere and there is no videos at all and not many on mercedes...
In attached pics that washer deffenitly wont fit on the subframe...did anyone with a SLK R172 had it done? Clk are different...
Thank you sll in advance
I believe you need to do both camber and caster bolts together for the camber to take it's effect. You'll only get a small change, bolts give a small fixed change by either positive or negative depending on bolt orientation. Now that the weather is better I'll need to do mine to.
Got Febi bolts from Autodoc, 2 for caster angle and 2 for camber👍
