uumode
- Sep 1, 2003
- C300 AMG Line Premium Plus
Bit cheeky asking here I guess, as it's to do with my Polo
I bought some sparks from GSF car parts and they gave me some Bosch Platinum ones which are supposed to fit my car - see below, and compared to the OEM removed plug it's longer! Does that matter i.e. in terms of mechanical fit and sparking point which will be deeper?
I also discovered in one of the existing spark plug holes oil/or fuel?
(Left hole is a typical clean one and three look like this, but the image on the right is the rogue one)
which left my spark plug tool covered
Do you reckon this is because the VW dealer crossthreaded / damaged the thread when putting in the spark plug? I checked if the spark plug was screwed in properly and it was tight. What's happening?
If it's of any bearing I also found some oil on my air filter and in the air filter housing. Older generation Polo's are notorious for getting blocked breather pipes so it 'might' be that or something to do with the spark plug? The car's done 68k miles and is 4 years old, so I don't think it's a worn engine (yet). I don't know why I have an oily spark plug?
