Sprinter 314 engine swap help
gonzalofv
mercedes W123 2.3
Hi to everyone
I will appreciate any help as my sprinter van engine is gone ( finito) but cant find any sprinter (petrol) engine , i know the engine code is m111 but not sure tht the c class with m111.xxx is same engine or not
i did so many modifications to the van , tv, wheels, leather interior and much more so i want to fix it
many thanks
Gonzalo
Hi.
Welcome to the forum........Ne'er a post about a 314 Sprinter in years on here and 2 posts in a matter of days.
So see my reply in this very recent thread containing a link for a replacement engine ( yes I know its far away ! )
http://www.mbclub.co.uk/forums/parts-maintenance-servicing/215991-sprinter-314-petrol-2004-a.html
You will see that the 2.3 NGT M111.984 petrol engines for these vans are very rare and therefore there will not be a great deal of folk ever having swapped petrol engines.
"Will a "C Class M111.xxx fit ?" Who knows you might be one of the first to try, but given the time and inclination most engines can be persuaded to fit. Many moons ago I put a SAAB engine into a Reliant 3 wheeler, so anything is possible.
Engine mountings, sumps and oil filters can be a problem, but can be overcome by using your original engine components. Clutches and flywheels can be swapped and check also the engine /gearbox mating holes. A big hammer is useful, as is some welding Kit.
How bad "finito "is your engine?? Is it possible to rebuild it ??
If the problem were mine I think I would rip out the engine, stick it in the back of the car / van and go find a M111.xxx petrol engine in a breakers yard and put them side by side and see how different they might be. You might be lucky and just get away with using the block and pistons you might not.
The Diesel engines such as in a 312 are canted over on their sides, is the petrol engine like this? This may affect your choice of engine as I presume petrol engines in the cars sit up straight.
There is much to consider, although fortunately there is plenty of space in the Sprinter engine bay for you to work with. There are those on here that would have you fitting a 5 Litre V8 complete with Supercharger !!
Which ever way you go it would be useful for other poor souls in your situation if you can report back on your progress (with some photos would be handy). I wish you well in your task.
Steve.
hi steve
thanks for your time
i now 50 50 undecided to fox it as mi time and money is really and ensue
i may sell it for part o i may fix it
Hi Gonzalofv,
Your 53 plate Sprinter still looks in good condition compared to my rusty old relic. You never did say why your engine is " finito ". Has it run a big end or splattered a piston.
It has been 3 months since you were last here, so the van has been standing unusable and unloved for some time now. Have you pulled out the engine yet? If not, then perhaps time to cut your losses and sell it on for parts, as you have managed 3 months without it. You should get a few bob for the nice alloy wheels alone. What ever you do regards a repair, it is going to cost ££££.
Steve
It looks a nice clean van,I would be inclined to look for another engine,or as suggested by Steve cost a re`build.
Hi I know that the Vito 111 engine will fit as ive done it twice a few years ago (different vans as we ran a couple). You need to change the sump and oil pump, meaning timing chain casing also needs changing. there is a blank plug in the block which you punch through for the new postion for dipstick. Its just a bit more work than a simple swap. If you can change the engine it should be not much more work. if it has variable valve timing just modify it to static. Both these engine lasted well over 100 k after. hope this helps
