You just need some copper grease (anti squeel grease) between pads and shims.
Tom
Tom
Cr4p (cheap) pads can also add to the problem.
There are many methods to stop brake squeek. Re-greasing is one, cleaning is another.
Brake squeek is a very common problem within dealers and most have develpoed methods to eradicate it.
I am now an EBC Greenstuf convert. Not cheap and squealed like a B****d (err..noisy) when first fitted.
They said this was a known problem for them but fitting anti-squeal shims and greasing the back of the pad fixed it stone dead.
Put Textars in the rear of a W124 and the brakes squeal in reverse. Replace then with MB pads and the squeal goes
Enough evidence for me to stick with MB pads
Nick Froome
www.w124.co.uk
