I have a 1999 CLK320 with 40K (low miles and service). The SRS light is usually on when I drive alone. When there is someone in the passenger seat, the following happens:
1. Passenger is under 60kg approx - SRS light on
2. Passenger is over 80kg approx - SRS light will start flashing after a while (25 minutes or so) and will clear if time is longer. Light will come back on next time I use the car after 10 or 15 minutes.
I have checked the connectors under the passenger seat and all seem clean, and wires in good shape. The MB independent says to bring in and spend $100 to put through a code check. I only want to spend $100 to clear the code after I fix whatever is failing if this is possible to diagnose through these symptoms. I have an SRS light clearing tool that came from China (worked a couple of times but no longer clears).
Questions:
Is it likely the seat sensor pad (I have read a lot about)?
Is it likely the wire connecting the seat sensor pad(I have links to how to attempt replacement)?
Is there a module under the seat that needs replacement?
I have heard about the child passenger sensor. Where/what is that and how easy to diagnose and replace?
What is a seat micro switch sensor? Could that be the culprit?
I appreciate any help with this annoying problem. I want to sell the car and dont want the buyer to experience this same problem
Questions:
