Bombardier
Bit of a dilemma here, started a couple of weeks ago, here are the symptoms.
2009 C180K, when i put the key in the ignition I hear the steering lock noise so that definitely is not the problem, I then turn the key to position 1 and all the lights on the dash light up but then when I turn it to the crank position.......... nothing, just silence.
I turn the key off and on again, sometimes it takes a couple of times to start, sometimes 7 or 8 times of turning it on and off, this only happens when the engine is cold.
I assumed the battery was in need of changing so I've just replaced it (at an unbelievable cost of £145) and this morning the same thing happened.
My Indi that fitted the battery and put it on STAR stated no faults were present, anybody any idea where I go next?
