Baldbloke
Well when the car went down at the back with your wife driving the ride height sensor must be right at the top of culprits to cause this,it is just a potentiometer ,if that is damaged or has moved then ride height will go up or down,as you say it is 50 miles to a indy,have a ring around local garages one may have a star ,I found a local garage which quiet frankly I would never have used but was told they had a star and knew how to use it.
Thanks Zipdip. I did renew the arm a couple of years ago but not the electronic box it attaches to. I’ll plan on jacking the car back up and sit it on ramps while I remove the arm from the antiroll bar and see if anything operates/ moves. I presume the engine needs to be running?
