Baldbloke
Is your newly fitted ride height lever, the one thats on the rear axle, adjusted to the correct length. Mine snapped and when I replaced it wasn't high enough so I had to adjust the length by trial and error.
Thanks for the reply. My plastic arm snapped a couple of years ago too. I replaced it with an upgraded Mercedes metal one. The height adjuster seems to be set as it’s fixed between the mounting plate which the sensor fits onto the body and the arm’s end which clamps onto the anti roll bar. The clamp fixing corresponds to a cut away on the roll bar so it looks like there’s no adjustment as such as it is pre-determined between the machining of the roll bar and the body fixing bolts
I did wonder if Star diagnostics has a capability to reset the sensor so that the air suspension can take more pressure, but that wouldn’t explain why the compressor needs to start up each time the engine is restarted.
I’m beginning to think there’s a leak that’s allowing the bags to mostly pressure up but not allowing the system to pressure up adequately for the proper ride height.
If there is a leak, and it’s at the valve(s) on top of the air springs it is odd that the springs don’t deflate completely after a few days.
I think it will have to return to the workshop for another soapy water test of all the pipe work joints
