Stromberg 175CDT (W115 200)
conor1939
Northern Ireland
1991 230E
Hi all,
I have a w115 200 (1976) with the Stromberg CD carb - the car is refusing to start unless I lift the needle/piston with a screwdriver, almost as if the piston is too heavy.
This one has the red cap, off centre with the damper below that. The needle looks to be sprung so am I right in saying it is probably ok? It doesn't seem to be worn.
I've put ATF in as dashpot oil - is this ok for a red cap? I think I've seen the odd forum post mentioning different oils for different coloured caps.
How much oil should go in there? Presumably too much will not allow the piston to rise properly?
What's the condition of the diaphragm around the piston? A small hole or tear is all too common and can cause all sorts of problems.
These are constant velocity carbs which all work the same way. At idle the piston shouldn't lift at all and therefore the diaphragm has no effect. There will be something that adjusts the position of the piston and needle at idle so if it won't idle it's either that adjustment or the enrichment device. The normal throttle stops adjust how far open the butterfly is at idle but there is still a stop for the piston and adjustment of the needle height.
The dashpot is simply a damper which slows the rise of piston and causes a temporary rise in air velocity in the venturi which in turn results in a temporary rich condition or accelerator pump affect. It's main impact is on the response when accelerating.
The diaphragm looks good but I've ordered a replacement just to eliminate it.
I actually bought an old Zenith 175 that came from an old Range Rover for a tenner to see if I could make use of any parts from it - the piston is a lot more free on that when I lift it, when I take the damper out of mine it becomes similar - is there anything I can do on that front, I have ATF in there - is that too heavy?
It's very strange!
190 - the richness adjustment screw if I screw it all the way in will lift the piston but its far too lean when its that far in, to get it to run I have to adjust the richness screw to a point where its down below the bridge, the piston is resting closed at that point as far as I can see! Should it be letting more petrol through at a higher setting?
I take it you've exhausted the internet's "how to adjust a Stromberg 175CD" pages?
From your description, perhaps the slow and/or fast idle screws are out of whack. Does it have an automatic choke? Does it work? Is it adjusted correctly?
This is a pretty simple guide but covers the basics.
The very first thing to do before any carb adjustment is to check the float level as an incorrect level impacts on the mixture especially at idle. According to my old 190e Haynes manual, the float level should be 18-19mm. After that adjust the idle speed screw which is the longer of the two, the other being the fast idle adjustment. ATF should be more than thin enough for the damper and the level should be up to the bottom of the inspection hole but it's of no concern anyway a far as idle setup is concerned and neither is the diaphragm.
I've scoured the internet for guides on Stromberg adjustment and tuning, some are very helpful and in the end I even managed to find a copy of the Haynes manual on Zenith Strombergs - the amount of variants between Zenith/ Stromberg/ Pierburg is staggering - I'm not sure I've seen a photo on the internet of one that's exactly the same as mine. The Ruddies website has been very helpful, from there I've been able to identify mine as a Stromberg 175CD (T- with automatic choke) "Build 3" - as fitted from July 1973 to July 1976. As far as I can tell the difference post 1973 was the addition of the pierburg fuel cutoff solenoid.
I'll give some background at this stage, maybe it will help someone to diagnose or help someone with similar issues!
I got the car in mid 2019, it was running fine but was quite hard to start, then once it was running I had to hold a bit of throttle on until it warmed up - I suspected the automatic choke wasn't working as I'd seen lots on the internet about the choke units causing problems. It wasn't a major problem, and once the car was warm starting up was no problem - I put fixing it on the back burner and enjoyed the car for a few months.
Fast forward to May 2020 and a friend's dad hears me struggling to start the car, offers to take a look. He has a lifetime of mechanical experience with older cars (although not mercedes). He checked the auto choke first and said that when heat was applied the coil moved as it should - I do wonder now if this is the same as it actually working as I see it has a power supply, does it require more than just hot water from the thermostat?
He checked the dashpot and the diaphragm which were fine, so he moved across to look at the distributor and the timing. That's when we saw it - the points in the distributor were completely loose, the screw holding them in had lost tread and was just rattling around. We put a new screw in, set the points gap and put everything back together. Car fired right up but now it had a terrible misfire.
Eventually we pulled the spark plugs and found them completely sooted up. The misfire persisted with clean plugs however. We called in a carburettor mechanic with plenty of experience, but again not on mercs. He adjusted the timing etc, but he found that to get the car to start now he had to connect a 12v feed directly to the fuel cutoff solenoid under the carb. Now at this stage none of us were sure of the operation of the fuel cutoff:
It needed 12v direct for the engine to start, and the engine would start and idle no problem but wouldn't rev.
If the engine was started and the 12v feed taken away the engine would rev put wouldn't idle.
I know now after trawling the internet and taking my own apart that the pierburg fuel cutoff should be fail proof, it was fitted from 1973 onwards and a corresponding delay relay was fitted from the no.4 fuse in the fusebox - when the ignition is switched off, power is sent to the cutoff solenoid for 5/6 seconds to stop fuel and prevent running on (190 I'm sure you'll know this already because it looks like the same setup carried through onto the W123s and eventually W201/124 carb'd cars).
Now, on my W115 I tracked down the little silver relay, it was disconnected - hadn't been touched by us so must have been disconnected all through my ownership. I had noticed the odd bit of overrun on hot days etc but nothing worth writing home about.
That said, I have no idea why we had to put power to that solenoid to start the car - I unscrewed the solenoid assembly which is one piece with the richness adjusting screw and gave it a 12v feed to see what was actually happening - all looked ok, with power on the tiny spherical plastic float stopper shot up and looked like it'd effectively stop fuel, then dropped again when power was taken away. The only thing I can think of is that when inserted through the float chamber maybe the fuel was causing it to float when it shouldn't have. it looks like there is a spring assembly in there but the sphere was sat somewhere in the middle of it, maybe it'd come loose etc.
My next thought was, well let's get rid of the solenoid altogether - enter my £10 ebay purchase Zenith 175. Its from an old Range Rover and doesn't have the solenoid. Its a simple adjustment screw. The float chamber and jet assembly is different, the adjusting screw much shorter - it does screw up into the jet on the Stromberg and is just about long enough to reach the bridge but petrol leaked merrily out past it. The W115 started up, I didn't run it long enough to let the exhaust get hot with the petrol leak (as much as I'm tempted to after all these months).
My thoughts turned to the original solenoid unit - can I just remove the float and spring so it acts like a normal adjusting screw? Well, no - getting them out would be impossible, the holes are too small and I don't want to damage them. What I did was take a thin nail and insert it down through the top of the unit, and gently tap the plastic float stopper down out of the way - that way it can't float up when petrol enters and if its not connected the solenoid won't try to force it up either.
That's almost where I am now - I put the adjustment screw back in, screwed it all the way up to just above the bridge and the car will start - if the piston is lifted with a screwdriver - and if its kept running until warm it will idle, so I went through the steps to tune it as outlined online and in the haynes manual; from idle I gradually made the mixture richer about 1/8th of a turn at a time, lifted the piston about 1mm each time until lifting it made no difference to the RPM. At that point the car was idling at maybe 1800rpm, mine has just the single idle screw that adjusts the butterfly valve - I unscrewed this to as close to roughly 750RPM as I could get, I still think it idles a bit high, in fact its worth noting that the car always did idle fast, again I assumed autochoke, maybe previous owner knew it wasnt working so had the idle adjusted too high to compensate?
With where I tuned it to it would rev happily through the rev range without backfiring and I took it for its first short drive down my lane in months, it actually would let me switch it off and back on again and I did that a couple of times, then I parked it up for 30 seconds while I cleared my tools away, tried to start it again and it just turned without coughing. Again I got someone else to turn it over, lifted the piston with a screwdriver and it fired straight into life. Very frustrating.
If you've made it this far thank you very much for taking the time to listen to my plight! I love the little stroke eight but its given me sleepless nights for months. Tomorrow during the daylight I'll have a go at setting the float level and try adjusting that idle screw back in a bit to see if that helps. Today I sprayed a fine mist of Fairy liquid and water on everything to check for vacuum leaks and all is good on that front.
Thanks 190 and Stratman for your help so far! I'm not ready to give up on the Stromberg yet, a brilliant learning experience if nothing else, you can probably tell a carburettor was a black magic "do not mess with" area for me not so long ago!
I suspect the power supply is to heat the automatic choke. If it's anything like the (massive) SUs on my old XJ6, there's a coiled bi-metallic strip inside the choke. When it's hot it 'unwinds' and turns off the choke, when it's cold the choke is 'wound on'. The power supply may well be from a timed source, which slowly-ish heats the strip and gradually turns off the choke. When the engine is stone cold and the ignition (possibly the starter circuit?) is turned on there should be 12V on the terminal to heat the bi-metallic strip.
I'm not familiar with your exact model of carb so I can only talk in general principles about CV carbs. The thing about a Stromberg is that there is no separate idle circuit. The idle fuel has to be provided by the jet that the needle sits in. That's quite a tall order given how little fuel is needed at idle compared with normal running which makes it very sensitive to needle position at idle. It starts when you lift the piston because that's lifting the needle out of the jet and allowing more fuel to flow. The problem is something to do with the resting position of the piston and needle. You mentioned earlier that the mixture adjustment does eventually lift the piston but the mixture is too weak to run. That's because the mixture adjustment is affecting the whole range of running. there has to be some other way of adjusting the needle resting position with respect to the jet. Later model CD3 carbs had needle height adjustment accessible from the top with a long Allen key but I don't think yours is of that type. Do you know the exact model designation of your carb.
I've done a lot of work on that carb in the past back in the day when it was fitted to the 115 230 engine.
Get your hands on a carb repair kit, remove the carb, strip it down and give it a thorough clean and reassemble. Also ensure that the flexible rubber gasket between the carb and the intake manifold is not leaking. They were notorious for minor holes when the rubber was old.
The 115 engines were not fitted with inline fuel filters and as a result a lot of the crap landed up in the float chamber and used to block the fuel delivery via the needle.. Add an inline fuel filter in the engine bay on the fuel feed line.
Also get a CO meter co that you can set the mixture up correctly and set it up to about 1.5 % after you get it running. This is done by adjusting the jet from the adjuster under the carb in the middle of the float chamber.
ATF up to the bottom of the filler is fine.
I had a similar issue on my stromberg 175cdtu had a fuel leak from automatic choke area. Stripped down the carb replaced gaskets and diaphragms all but the one on the automatic choke as one of the screws is stripped.
how would I perform a vacuum test/check with the carb off the engine? Also a way to check the automatic choke?
I triple checked the floats set to 16/17mm new float needle also.
Any ideas? I was looking through the startek manual but seems to be missing one pdf 072-136 if anyone has this would be handy
(circled pic shows where leak was)
I m sure by now you must have solved the problem.
However, when the engine wont start unless you left the air valve piston, this means the Fuel to air mixture is very rich.
close the fuel screw to the end.
turn it open (i.e., counter clockwise as you look at the carburetor from below upward) for 420 deg. (that is 1 1/4 turn)
start the engine
wait until it worms
use the screw driver to left the air valve piston (for about 1-2 mm):
if the motor goes faster, you need to reduce gasoline (turn the fuel screw clockwise ) for 1/8 the a turn
wait 30second until the engine normalizes and then try again
if the engine is likely to die , increase the fuel. (turn the screw ccw).. and repeat.
until the engine slows very minor or stays as is (does not die)
this should be the right fuel to air ratio.
Good Luck
