I took the car today to have the crank position sensor changed, when I arrived to collect the car the mechanic said that when you turn off the engine you can hear a grinding noise from the super charger. I’ve never really noticed but now he has pointed it out its all i can hear.
I have read on other forums that you can replace the supercharger bearing which is a quick fix, as Mercedes will want to replace the whole unit.
has anyone had a similar problem? and if so some advice would be great.
