Probably till the summer i reckon,Are you keeping it now?
I think you might have in the pastView attachment 125474
Did I mention how pretty she is lol
Sue's CLK has the dash clicking occasionally and pretty sure it is the most inaccessible on which requires dismantling the entire dash!! It would be liveable if not for the fast that demisting is a nightmare and it is either roasting hot or freezing cold in the cab - I am assuming the two events are connected? Any suggestions more than welcome! Actually, I may start a separate thread as it may well help others in the futureSo small update,
I had the Engine mounts done, Along with a tie rod end for the MOT,
As per the Mercedes Benz TSB it was indeed the engine mounts causing the tapping!!
So a lovely quiet drive once again until...... wait for it.....
The dreaded clicking behind the dash, and to top it off the same clicking the c220 suffered from has stopped! doh.....
So Suzzie has a sticking stepper motor whether this gets better with use i have no idea, as the c220 has the same fault but since racking the miles the fixit fairies sorted it. Lets pray same happens with the cab fingers crossed.
Yes I am going for the CBA to shave look lolSaw you going past the putting green car looking great,from a distance for a second was not sure it was you,it was the beard that fooled me
