That was Swotty in July 2014, he will know
Just answered ..... I've lived with it for 6 years and then got fed up! Now sorted.
Intermittent front left indicator was finally rectified by the Merc garage when they replaced the front right ABC strut last month. "They usually go", they said (the indicator) - faulty wiring is the problem ... the bulb still works when the hazard warning lights are activated. They charged for a new "connection unit", so sounds like the same component.
Door mirror ... retract/open functions only work on one of the keys ... perhaps I need to programme the second one?
On the first key, they retract/open and dip in reverse fine, but passenger one does not return properly when reverse has been activated. I press the retract button on the door panel and then the open button. All is then fine, but I don't know if this is a wiring break (on the reverse circuit) or something else. It's a quirk and I live with it!
Couldn`t agree more. Incidentally now knowing the relative rarity of the CL600 it would be interesting to gain an owners/past impression of one........
Swotty, Oxey, Phil Woods or mark-le-b perhaps ?
Sorry, late again, but here goes ....
I bought mine (2003 TT) in 2014 with only 46K on the clock and full service history. Was fine for a couple of years and then I've had to replace the coil packs, the ABC pump and now the front right ABC strut. Also a wobbly prop-shaft. Also have the usual oil weep from the cooler sat in the engine "V", but it's so fine that it's not worth the €000s to get it done.
Had the a/c cabin thermostat go and the a/c /heater motor became noisy but has settled down again. Noisy petrol pump turned out to be a faulty fuel regulator. Had the usual front passenger seat occupancy light fault, sorted again by Mercedes.
The front suspension is creaking and Mercedes want €2k to replace the wishbones and tie rods, so I'm going to spray all the bushes with lithium grease to see if that sorts it, albeit temporarily.
Other problems? Well, it's in Iridium Silver with black upholstery and there are about 4 or 4 small spots of oxidation which have bubbled up through the paintwork but which are not getting any worse. I know the rear right ABC unit will need replacement in a couple of years and presumably both l/h side units in due course. She's also still on 18" Difdas ... and still silver!
I had the gearbox oil flushed and changed at 50K. The box is supposedly sealed for life, but it's exactly the same model which is in my XKR (as Jaguar bought in the Merc Box, not having one of their own which could handle the torque of the supercharged XK) and the oil does need changing as a number of XK owners can testify.
The Merc garage in Bergerac (complete shysters) wanted to charge me €900 for dismantling, rectifying and reassembling the box due to an intermittent fault - again, this is well known in the Jaguar XK Club and the solution is to disconnect, dry off, clean and reconnect the plug at the rear of the box .... €50 at Mercedes Périgueux, who are brilliant with the car.
Had to have replaced the primary and secondary air pumps (?) which operate on start up.
She's on 66,000 miles now and I rotate the cars so am only doing 2,500-3,000 miles a year in her.
If I wasn't having a classic renovated and another upgraded, plus trying to sort a hiccup on the XJ6 (just changed the injector seals - we'll see!), plus the recent expenditure upgrading the XK ... and the new garage to house all the cars, I'd love the have the CL repainted, possibly wrapped ... but the interior will still be black. I'd also like bigger wheels and a more tuneful exhaust. However, Mrs Swotty has put her foot down with a firm hand since I bought the Corvette earlier this year (although she loves it) and insists I spend more time and money on the house and pool (she hates both).
I have had numerous conversations with friends in the classic car club who have bought older premium cars ... Bentley, Rolls, BMW and who moan about the cost of the upkeep. The only thing which is cheap about such cars, like the CL, is the initial purchase cost - you still have the annual running costs of a premium motor. Without checking, I reckon I have spent as much on the servicing and above-mentioned maintenance as I did on the purchase price, which was £8K.
As a cororally, I need a new kingpin (only the one side) for my 1965 Wolseley. This was, in the day, a part common throughout the BMC range, but they were also fitted to Jensens ... so the price nowadays is the Jensen price ... £400 for a pair! I have bought some new bushes and will see if they take up the slack ... Yorkshire thrift sometimes works out.
Sorry for the rambling ...... the CL is a beautiful, classic shape I have always admired. It seats 4 adults in spacious comfort and is effortless to drive and park, even in the narrow streets of the local towns. Everyone who has been in it has been impressed by the space, ride and serenity. Yes, it's not an S Class, but it is both elegant and refined.
Oh ... and there's the engine. Thinking of getting a CL, I did a lot of research. The '55K was the obvious choice, but I had the supercharged V8 Jag XK and wanted something more refined ... and powerful. I tried both '55s and 600s and the difference was night and day, so the 600 it was. The peak torque range is both phenomenal and real-world usable, even nowadays.
If you want to run a premium and powerful car you must, in my opinion, be prepared to have, in effect, a sinking fund for maintenance ... similar to building maintenance. Mine has cost me around €8K over 6 years, so around €1300 or £1200 a year. That includes servicing, tyres and the above-mentioned repairs which are well-documented with the model. I spent £1000 last year on a new clutch and service for our runabout Fiat Panda which has only done 35,000 miles in 15 years.
I did my research on the 600 ... coil packs, ABC pump and struts, door wiring harness problems, oil cooler leaks ... so was disappointed but not surprised when most of those happened ..... and will continue to happen.
Do I regret the purchase? Not at all.
Will I keep her? Of course ... unless an equally maintained and cared-for example comes up in red/burgundy with beige interior!
Is she an investment? Not at the moment ... possibly as a Newtimer in 5-10 years' time.
Would I recommend the model? Try a '55K and then a 600 and judge for yourself. They are very different. I have 2 other V8s (which are both very different in themselves), so the 600 is a more refined performer.
Apologies for yet further rambling ... hope that is helpful.
Excellent, thank you. Have you still got your car ?
Hi, yes, and intending to keep her ... unless a red/burgundy with beige interior comes along ... the silver is oh so commonplace!
@Post No.24. Brilliant post indeed Swotty & of considerable interest to us all, grateful thanks.
The creaking suspension is documented elsewhere & often overcome short term by injecting grease into affected boot(s), Lithium should
do fine.
There are recommendations now to renew the gearbox oil every 50K.
Your comments on ownership costs & renewals will attract attention for any incoming owner., which is needed.
I sold mine four years ago replaced it with my CL 216 63 Biturbo.
Also Mr Kipling has sold his.
Still have mine...4 years on. Though probably only about 2000 miles per year at present. Dearest thing to go was the instrument cluster...£90.
It’s funny how the dire “ABC expensive” myth is still alive.
The system is better understood now, and the MB ‘never needs attention’ has been debunked too (much like gearbox sealed for life).
Regular fluid changes will prolong the life of the system.
MB actually do a recon pump for around £500ish.
Valve blocks can be rebuilt with Viton o rings, I think the kits are around £85, there are experienced indies who can do it for you.
The pulsation dampers/spheres are about £170.
Time has made it much more understood by Indies, and much less scary. The parts are much cheaper. (I think when I bought my CL the pumps were around £1500, and valve blocks £500).
It is similar to the suspension banned on F1 cars, (because it was too good) and is superb, comfortable, supple, yet when you hustle it keeps the car flat, and stable.
They are achingly beautiful from all angles, and just so special to drive on a daily basis.
Mine has just sailed through its MOT. 20yrs old this year, but oh so timeless.
