The weather has been cold, no very cold and its been harsh on our old R107’s. Mine is at 1972 350SL. I try to drive mine twice a week to keep things ticking over. But as of late I have noticed difficulty when pulling away after starting but after a few minutes of careful driving revving and the engine warming up the car runs smoothly
I’ve also noticed small knocking noise, think it might be the tappits can these wait till next service or is it something that needs urgent attention. Or it might be that I am using the wrong octane fuel (normally 95 RON). I have heard of other early 1970's 350SL fuelled by higher octane fuel like Super unleaded - 98 RON, I use Ordinary unleaded - 95 RON. I know the old 4 Star leaded had 98 RON. Is this the fuel I should be using as I don’t use lead additive and my car is 1972 manufacture. If I continue will I damage my engine and if I change will I need a re-tune. Wish I knew more about car mechanics.
Another item I have notices which has got me scratching my head is slight mayonnaise on the oil at the end of the dipstick, I know that mayonnaise under the oil filler cap can be a sign of early head gasket failure but it’s only appearing on the end of the dip stick. Racking my brain as to how water is getting in at the end of the sump. Also the oil levels are not dropping appears to be at the full level and slightly above over the past 200miles. More potential worry for my dear R107
All help is much appreciated, and thanks for departing you knowledge on the above items
