shanksy
Hi all,
I have purchased an original loom for heated seats including the trim and switchgear, however...........
The heated seat pads I have been looking at are the Waeco MSH50 (£65) and the MSH200 (£125).
The cheaper ones are made with elements of coated wire, the more expensive ones are higher quality carbon pads able to be cut to size.
I had resolved to get the more expensive ones as I thought being able to cut to size would make the install easier in case there are metal supports in the seat base or something.
My problem is that the more expensive ones have a dial with variable temp control, whereas the cheaper ones have 2 different heat settings (as per the original factory fit option).
My question (finally) is for someone with a bit of electrical nous, will I have a problem wiring to the original loom the pads with the variable heat setting or will I be able to bypass that so I have just the 2 heat settings ?
Any advice greatfully received as i'd hate to spend loads and be unable to fit them.
Cheers as always
Cheers as always
