reflexboy
My wish is to own an SL (R230) before my 40th birthday. I have been doing a bit of research, initially wanting an SL500 but looking in depth at the SL350 it may be a wiser buy. It seems the original SL350 was a 3.7 which was almost on par with the 500 mpg wise. MB then facelifted the 350, replacing the 3.7 engine with a 3.5 in May 2006. The smaller, 3.5 had considerably more BHP (272), was quicker 0-60 and was a fair bit better on fuel. This newer engine has a pretty respectable 0-60 of 6.6 seconds compared to 7.2 seconds with the older 3.7 engine. I also understand the SL350 was facelifted again in 2008, bringing the BHP upto 306, although that model would be out of my budget range. I more or less definately want a late 2004 as that's when the command was changed to the widescreen version which I think looks far more modern. I would prefer to buy one from MB due to the complexity of the car, as I think an AA 5 star warranty or similar may not cut the mustard should a fault occur. My thinking is if I buy a 500 will it sit in the garage doing nothing as I will scared to take it out as much as I'd like and be broke within the year. On the other hand if I buy an SL, there is no point leaving in the garage, as there's no point having an expensive car sitting doing nothing-it needs to be driven. It's too much money tied up in a car not to be used. My budget will buy a 500 or 350 from MB upto about 2004/5, but not a facelift 350. I have however seen a couple of 2006, 350s from independant dealers, but am worried about the warranty. No doubt a few of you have been through the same dilema. What did you deciede or what would you do in my situation? Any advice would be welcomed
