Some of the issues to look out for are :
Seat sensors .
All seat heating(top and bottom) /electrics.
Leakage of oil from rocker covers .Take it for a good solid run and push it . If there are any issues you will smell oil .
Leakage of oil from rear crank seal .
All electrics are working 100% as expensive to repair . Double and triple check them .
Noisy ventilation flaps on start up might mean on there way out .
I would strongly advise to take it to Merceeds specialist to put it on a Star system to bring up any error codes .Check derive history and call the people that serviced it and and ask a few questions
As to the brakes and discs, they are very cheap of Mercedes now. I had purchased from pads for £55 ! Discs are probably £120-£150 ,so relatively speaking not too bad now .
Quad exhaust are standard on that model as its a coupe . It's on the cabriolet thAt they had only a twin on the near side due to the additional chassis bracing .
As had been previously stated ,it is a tad on the dear side ,but I know prices are starting to rise on these models now ,well on the cabriolet at least
As to the MPG ,you will get 15-20mpg in the real world if you drive it easy and use cruise control .
Hope this helps and good luck.
MERCEDES-BENZ CLK55 AMG 2004 AMG PERFORMANCE PACK/QUAD EXHAUST/FACELIFT | eBay
Considering buying this. Can anybody offer me advice on what sort of things go wrong on these cars and does it appear a good car?
All the advice you can give will be appreciated..
