Hi guys, I have a 2001 ML270 CDi, it has black death. I waited for the warmer months to start working on it.
I had previously loosened the old bolts and was planning to replace them with (not fully torqued) new stretch bolts, and run the engine hot enough to remove the injectors.
When I was removing the hold down bolts, to my horror, I found some idiot mechanic had installed short (half length) larger diameter bolts than the OEM stretch bolts. At first I thought I removed the broken half of the stretch bolt, but when I inserted the new OEM bolt, it went all the way in.
Three of the bolt holes did not have their threads stripped and I was able to replace them with OEM stretch bolts. But the fourth one won't tighten, it just turns and turns. Some bastard stripped the bolt hole threads.
[I couldn't reach the fifth one as it's under the coolant reservoir but has the same larger diameter short bolt].
What am I going to do now - the thought of heli coils fills me with dread.
