Time for a shocks change?
BenzComander
Bucks
E320 Avantgarde Estate
As my E320 Avantgarde Estate has covered 132,000 miles, I feel it would benefit from a shock absorber change to sharpen it up a bit. It's OK on the Mway but is a little rolly around the lanes :D
Anybody got any advice regarding OEM V aftermarket?
Also, while I am in there, any other items, bushes, springs etc that I could change that would improve the ride/response?
Cheers,
You'll notice a huge improvement after fitting new dampers. At the same time check all the usual culprits like anti roll bar links, ball joints etc.
In the workshop I normally fit Bilstein dampers.
B36-2154 front upto 99 W210
B36-2155 rear upto 99 W210
B36-2156 front after 99 W210
BE3-6203 rear after 99 W210
All these for cars without self leveling.
regards,
Job
jgevers said:
regards,
Job
Thanks for that Job,
What would be a good price for the dampers?
Do all the estates have the self leveling suspension?
And if so does this greatly complicate things?
Cheers,
I don't want to mention prices on this board, as this might be taken as commercial because I own a garage.
But the shocks can be bought cheapest from Euro Car Parts.
regards,
Job
Bilstein/Eibach kit is oem MB (some springs/shocks have both names on them for some reason!) so you might want to check the price of the oem items, although I don't expect they will be cheaper on this type of part, not when the aftermarket is so competitive for suspension components.
OEM MB shocks are either made by Bilstein or Sach. I would just get the Bilstein ones as they are probably cheaper and just as good as original merc ones, if not better.
try http://www.motorsportworld.co.uk/ for prices
also it is best to check with your insurance company first before fitting lowering springs, (eg Eibach) as if you have a crash and if you did not declare the modification, your car insurance may become void.
What would the Bilstein part numbers be for a 99 Elegance with Avantgarde Chassis and suspension? I know it sounds strange but it was a factory spec listed as a Sports chassis, but I have been told it is the same as Avantgarde.
There is a chassis break in 99. Call Euro Car Parts with your chassis no. to get part no. and prices.
Regards,
Job
