Jul 1, 2004 #1 M mercyboy New Member Joined Jun 19, 2004 Messages 16 Hi, Is there any other parts i need to fit when changing the timing chain, Also is this chain change an easy job, Thanks Paul. p.s my car is a 1984 230e.automatic
Jul 1, 2004 #2 guydewdney MB Enthusiast Joined Feb 14, 2004 Messages 2,912 Location Porlock, Zomerzet Car 906 Sprinter 313cdi yes, the guides are a good idea...
Jul 1, 2004 #3 Ian B Walker MB Enthusiast Joined Jun 7, 2003 Messages 7,668 Location Freckleton Car 300-24, saloon and coupe, E300 24 valve diesel estate guydewdney said: yes, the guides are a good idea... Click to expand... If you can remove the pins, they can be tricky to get out. But good advice all the same. You may want to renew the tensioner spring as well.
Jul 1, 2004 #4 OP OP M mercyboy New Member Joined Jun 19, 2004 Messages 16 Okay Thanks for the advice guys, will pass the info on to my mechanic friend.
