Only thing with jetwashing block paving is it washes the fine sand out of the joints, so you then have to re-sand what you've washed - so I don't do our front driveway very often, just spray weedkiller as required! Jeyes Fluid is also supposed to be good.
If you've spent the weekend working on the car and have lots of oil & grease in your fingerprints and under your nails, ask your loccal buther if you can have 10 minutes kneeding the sausage mix.
When building a submarine, put all the pipes that always spring a leak when being depth charged, on the outside. That way when they leak, it doesn't matter!
To the forum member who recommended smooth Peanut butter to make tyres shiny...... I hope you're having a good laugh! No, it doesn't work even slightly, but does leave peanut-butter-brown slime all over them.
