Tired Key Fob
Hi Ian,
No probs - I have a message into Gareth right now.
Do you have a direct phone number for him?
Ta
Gary
You have not made enough posts to qualify for being able to send a pm to a member..I think you have to make 30?? posts first....its a security thing.
Hi there,
I would like to contact Gareth for a new casing for my key. I can't PM himas I do not have enough posts. How should I contact him?
my key fob fell apart the other day it is part number 14076003/0708, is it possible to just get the platic shell rather than having a full new key ((mb in mk quote me £185 for a new key with all the palava off having to bring in all the required paper work etc and they say you cannot just get the plastic key fob itself)
i am currently using my credit card key to unlock the car, I also have a 2nd set but the alarm unlock does not work on it (also has a different code 1407601406) and is slighly different (the red plastic IR cover is slightly bigger) but the actual flip out key does work
I've just got a new replacement case, How do i get the board out to swop over ?
I've removed the batteries and can't see a release catch to get the green board out.
There's a piece that looks like a white bar. Remove it...carefully...and the PCB will fall out.
I seen the white bar, I take it I need to use maybe terminal screw drivers or similar ?
Does this white bar go back in easy enough ?
Thanks :thumb:
Goes in easily. But if you damage it there'll be one in the new key. Either way you'll learn on one key...
