I own a MB c200 1995. i wonder if anyone out there have had similar problems as i am going through at the moment. My dashboard and heating control back lights flashes and i loose control of the controllers, when that is happening the heating system will be constantly hot. This problem is on and off. I have had the controller console replaced by that did not cure the problem.
A week ago, I was told by a machanic that the alternator needed changing, after replacing the alternator the car have developed more problems.A day after he replaced the alternator, the car could not start without a jump , so i took it back , the guy sold me another battery but this l did not cure the starting problem.
I managed to start with a jump start, but the battery did not charge up infact it seemed to be loosing more power as i was driving eventually it lost all the power that the in stereo and inside lights just switched off on theri own. I had to call breakdown services. The car was toured to the same gararge and the breakdown services guy told me i have an electrical fault and my cat needed replacing. Is it normal for a cat to blow all of a sudden, can a cat cause the drain on the battery.
Is it a combination of problems i am having ? whow best and economically can i sort out the problems please help
