Aletank
I think, not sure though, my track rod end might be on its way out here's my symptoms -
1. When I got my full steering lock on and turning right there's like a rumbling noise, mainly sounds like its coming from the near side front wheel.The noise is worse when turning on a camber, say for example straightening up after reversing out of the drive.
2. Jacked the car up today and there's a slight bit of play when you shake the wheel, not much though and can here a slight click if you listen closely.
3. My Near Side Front tyre is worn on the outer edge all the others are fine even the off side front is fine.
The main symptoms being the rumbling noise when I've got my full lock on and that tyre worn, The play and clicking noise when shaking the wheel is only very very slight.
The car is due for a B Service the end of the month so might mention it then and its due a MOT in February too. The cars done 60,000 miles
Anybody any ideas - could it be the track rod end ??
Thanks for any suggestions/advice
