jakewinning
- Jun 20, 2017
- C250 AMG Sport
Hi All,
Just picked up a C250 AMG Sport Automatic 62 plate, 47k miles. As I've just picked it up and it's due a service I've dropped it into a Mercedes Indy for a few bits of work, here's what I've gone for:
- Service B (which they tell me includes Air Filter, Pollen Filter, Fuel Filter, Oil Filter and Oil change plus the other necessaries)
- Rear Axle Oil Change
- Brake Fluid Change
- ATF Fluid Change
Now my main question lies with the ATF Fluid Change. I've read some really conflicting thoughts on this. Most people seem to say that you shouldn't touch the Torque Converter and shouldn't drain it (which is also what this garage believe on a car of this age). Others have said that if you don't drain it, your just lazy..
My question is, am I doing the right thing by having these guys change the ATF Fluid without Torque Converter? Anything else I should be worried about? The car also seems to jitter ever so slightly when cold on gear up, from what I understand this is standard with the 7G?
Thanks in advance and sorry for the long post!
Cheers,
Jake.
- ATF Fluid Change
Cheers,
Jake.
