I changed my transmission oil and filter last year. But today, I sent the car in again to change the transmission pan. They used the latest pan which is curved at the front. At the same time, they changed the oil and filter again.
The mechanic could not find the Torque converter plug although he turned the TC all the way.
So, he basically opened the cooler lines (at the front of the car) to drain additional old oil. The flow was very thin but it kept on flowing for 10 minutes. He used only 3L of oil to flush which I know is not enough.
Just to note that he did a full flush last year using much more litres of oil.
Only (almost) 6 litres of new oil was used to fill up the transmission. He assured me that he closed the drain plug as soon as the oil excess flow started to sputter to have the correct level.
Do you guys think that:
(i) it is strange that only (almost) 6 litres was used to refill the transmission?
(ii) Is it important to flush the transmission with "x??" litres of new oil at every oil change for cars which do not have TQ plug?
