wu56Shoozz
- Jun 17, 2016
- MB Vito 111CDi / W203 C Class Saloon 320CDi Avantgarde
The car is a W203 C Class 320CDi (2006)
So yesterday I went to replace the seals on the turbo intake hose. (By the looks of things mine had not been changed for a long time.) So upon re installing the ducting the connection just all broke up like pencil lead.. very brittle indeed.
My questions are:
1/ Is there a set way on installing the ducting so as not to damage the connector to the turbo?
2/I've read that changing the seals only, can make things worse instead of better regarding oil leaks - can someone explain why, as I have a fear that mine will do this on reinstall..
3/ Is there a way to remove the existing MAF sensors to install on the replacement hose without damaging them??
I have a plan to heat the connector end in boiling water as to expand it and possibly soften it a little then install.. but its just a theory.. any help much appreciated..
My questions are:
