Tv upgrade CL55 2001
911mani
Help please can anyone advise me on upgrading the in car TV from analogue to digital as presently the analogue TV is not working.
Thanks.
Speak to Comand Online Ltd.. They are traders on the Forum.
C43AMG. Hello mate thanks for your response. I have had a search for command on line ltd on the forum and can't seem to come up with a result. Do they have a telephone number or any other contact details that can be provided. Thanks in advance.
Just google them , they're the first hit.
Based in light water in Surrey , not much they don't know or can't do !
Some of the analogue tv tuners have RCA AV inputs.
If yours does then the easiest/cheapest way is to buy any digital TV tuner and piggyback it into your old Analogue tuner through the RCA inputs.
Hopefully yours looks something like this :
And you can then fit something like this :
Car Digital DVBT TV Tuner Receiver MPEG-2 12/24V SD USB 2xVIDEO-OUT AV-IN | eBay
That's what I did. See pics.
I fitted it more for playing videos and music rather than watching TV as reception is often iffy. Loaded the videos and music onto a 32GB SD card that goes into the tuner. There's also a USB input so I fitted an extension lead for that and fed it into the cabin along with the remote eye. If you want TV you need to remove one of the four aerial inputs to the analogue tuner and connect it to the digital tuner. My analogue tuner was the older type without RCA sockets but you can get a conversion lead for it that has the multi-pin connector at one end and standard RCA sockets at the other. The aerial connections differ too so it needs a diy job to change them.
Very neat
Thank you very much to all you guys for your help. Much appreciated. When I have the issues resolved I will post it on the forum.
