Tyre Pressure - is this correct?
Grrrrrowler
Hi All
I have a 55 plate c220cdi with the 5 spoke mercedes alloys.
According to the sticker inside the filler cap the correct tyre pressure is 33 psi.
Is this right?
I have inflated them to 33 but it feels a bit 'bumpy'...
Is this the right pressure?
Any help appreciated...
Cheers
The pressures are only a guide.
Generally, put them there and drive it. Then raise / lower by 1psi and drive again.
Repeat until you find a sweet spot for your car.
Thanks - I'll try raising by 1psi tomorrow and see how it goes...will 1 psi really make a big difference to the ride?
Edit: thinking about it maybe I am better reducing it lol...
Are these 17" tyres?
33 to 35 psi would be about right.
I wouldn't reduce below 33 psi if that is the pressure stated on the car. Reduce the pressure to much and you will get tyre wear and drag.
