Welcome to MBClub Edward. I’m sorry to hear about your wife’s paintwork issue.
I would suggest that a fresh start with a main dealer from a different dealer group, and with a slightly gentler approach. It’s an emotive situation to be in, with such a large outstanding finance balance on a 5 year old car, but if you can emotionally remove yourself from the situation, remain calm, and ask questions to understand them you may find that a second attempt may get you further, quicker.
For example if they say that the car has been painted all over, then ask how they know that. If they say they are a professional and can just tell, then ask them whether they use a paint depth gauge to help you understand as you don’t have their professional eye. When they show you the depth on one panel, ask them to show you the paint depth in all panels if all panels have been resprayed.
There’s an element of discretion in goodwill repairs, and I’ll bet you a weak pint of larger shandy in a sunny day that if it’s repaired then it will be done as a goodwill gesture. Go about it in such a way hat the bodywork staff support your cause and you’re more likely to be successful. There’s always the possibility that it has been repainted too, so I’d hold fire on court proceedings until then.
Wishing you and your wife the very best in getting this sorted.
Hi Markjay,What's the car's pain code? This will clear it up.
Thank you MarkJay, I am proceeding as you have suggested.Welcone, and sorry to hear about your troubles.
Indeed, it has been hit-and-miss for many owners, some had a full respray without issues, other had to go through a lengthy battle first, and some were declined anyway.
Two points to note:
At this point, the obstacle you're facing is a non-cooperative dealer, I.e. MB have not dealt with your case yet, they'll only become aware of it once the dealer send-in their report. In this situation, it's always a good idea to try a different dealer.
Then, regarding the legal aspect, your current issue isn't that MB denied liability, but that the dealer claims that the car had a full respray previously. Regardless of whether that's true or not, the point is that if the dealer refused to inspect the car on the premises that any paint damage won't be covered anyway, then you could find others to join you, but at current the dealer isn't denying liability - your issue is in proving that the paintwork on your car is indeed original, and that in itself is not a basis for a class action law suit.
I suggest that you proceed as planned and get an independent report regrading the paintwork, then see what the dealer says, and take it from there.
Best of luck.
I believe it Mercedes Jupiter Red Code 589Someone here will know.....but I thought that they had discontinued the troublesome Fire Opal paint before 2020..... what colour is yours @foxe01 ? It needs to be a solid, non metallic red.
It's not unknown - Google "Mercedes Jupiter Red problems"Hi Markjay,
The paint code I believe is Mercedes Jupiter Red Code 589.
Is Jupiter Red known for having the same problems as Opel Red?
Here you go...It's not unknown - Google "Mercedes Jupiter Red problems"
Someone on here had a Jupiter Red car which needed a full respray if I remember correctly.
Hi @ALFAitalia,Cinch have a bit of a rep of selling damaged cars that were not recorded by insurance companies....Google it. So it's not impossible that they painted it. Also things happen. My mate put his near brand new 5 series through a hedge.... only light paint damage....but he had both sides sprayed at his cost and kept the insurance out of it.
Hi @SpikyMikey,It's not unknown - Google "Mercedes Jupiter Red problems"
You're welcome.Hi @SpikyMikey,
Thank you for remembering this documented case/ situation in MB Club.
It’s also a GLA from 2020 in Jupiter Red, that got a repaint by MB as a gesture of goodwill.
This reference will deliver huge leverage in my case.
Thank you so much for sharing.
Edward
They used the no service history with MB as the initial reason/ excuse for no inspection should occur...
