Upgrading Pre-Facelift CLK Centre Console
Hi I am changing my c220 to the facelift dash,it can be done going by the web site you have,that is the one I gave to my car electrics guy,just him getting to do the job is the problem(time wise).do not forget the housing at the back of the audio 10 has also to be changed,wiring on heater unit is plug and go,wiring on the radio has to be completely changed,aerial connector to fakra and conversion plug to iso is also needed,there is a bit of play required on the top switch panel as the hazard switch works on pulse instead of just on/off.let me know if you succeed and I will do likewise,good luck,hope some info. Above helps.
Hi. Will let you know how I do. Im going to do a "basic" write up of the whole thing in simplified terms from start to finish to help others who want to do the same. I have all the parts now but still looking for a diagram on how to remove under the dash, steering and arm rest etc etc. I have a Mac so buying the discs isnt really an option all be it if I have to I will have to get the discs and ask someone to print out the pages I need. Im one of those people who hates to be pulling at things not knowing if there are hidden screws or where the clips are (if any) etc
