IBN
Hi Guys
I have a really annoying problem with 300SL (W129) .... I cannot fully turn off the alarm system and I urgently need help /advice.
The car is a 1990 (US Spec) with what I think is an infra red (as opposed to radio) plip .... it has sensors by each of the doors (and by the boot lock) which register green when you are unlocking the car and red when you are locking it.
A couple of weeks ago, I decided to take the "old girl" for a spin, so I removed the covers and disconnected the CTEK (which I leave permanently connected). I got into the car and started her (she fired first time) and selected reverse gear to back her out of my garage .... As soon as I selected reverse the alarm went off and headlights started flashing etc. I thought this was strange because the doors weren't locked and therefore the alarm was not enabled. So I stopped the engine, got out of the car and disabled the alarm using the plip (pointing it at driver door sensor) This disabled it until I got back into the car, started it and selected reverse gear when the same thing happened.
I also seem to having problems with arming/disarming the alarm using the boot and passenger door sensors. If I lock and unlock the car using the boot sensor, the alarm is triggered immediately I open the passenger door, if I then disable the alarm using the passenger door sensor, I can open /close the door without triggering the alarm but cannot open the boot without doing so.
My problem is I cannot now drive the car because of this issue and I seem to be going round in circles trying to diagnose the problem. I live in Northern France and my nearest dealer is nearly 50 miles away so if possible I like to sort it out in situ rather than pay for the vehicle to be transported to the dealer.
I have tried disconnecting / reconnecting the battery (per something I read on a US website) but this doesn't solve the problem.
Your advice / suggestions would be much appreciated!
