R2D2 said:
OK. Blassberg. Many thanks for your advice but it didnt work on his machine. I really appreciate the efforf though.
Mac. When he hits F2 it says entering setup then just stops!
Splang. I havnt a clue how to do that!
Hmmmm.
The fact that it says entering BIOS is an indication that PSU,CPU and RAM are all functioning (otherwise you would get a black screen and nothing else).
How long did you wait for the BIOS screen to come up?
Sometimes if there is a prob with the hard drive then it can take a while for the BIOS screen to appear (waiting for timeout on hard drive).
Splang's suggestion of re-flashing the BIOS could be on the right track.
There are a couple of things you could try first though.
1) Try and re-seat the hard drive.
This is usually mounted on the side and is accessible via a tray normal held in place by one or two screws.
Unscrew them, pull out the drive then fit it back in (obviously with the power off!)
2) Reset the BIOS to factory defaults. This can be done by entering the BIOS (setup screen) and the choosing the 'restore to factory defaults' setting.
Are there any strange noises?Like a ticking noise perhaps? Sometimes when the hard drive is having problems seeking the heads make a 'ticking' noise.
Could be an indicator that the drive is duff.
Mac.
