silverarrow
- Mar 19, 2004
if you have had a low coolant light flash / come on and your temp is above 90 then fan control relay under the passengers side front wing is duff part no a0275457732esg600 this when you check with the main agents is on back order however they are whats called on chassis number release this part is known to fail often and has been modified with the following part number a0255455932 so if that low coolant light is on and not low on coolant then get one ordered also it does control the air cond . check your temp gauge should not be above 90 except in very high ambient temps and if towing up a hill normal temp is 90 with new coolant
