Number_Cruncher
>>Could i get one from anywhere else which would do the job
The problem with most small flimsy 2 legged pullers is that the legs tend to splay out and come off the wishbone. The ball joint is very tight as you press it in. You *can* use a 2 leg puller, but, it's much easier with a bearing puller. The advantage of using a bearing type puller is there are no legs to come apart under load.
