Using EOBD code readers with Merc ?
No reason why not, I use a Bluetooth ELM327 with the Android version of Torque Pro and it works well with 2012 and 2013 Citroens and 2013 Vauxhall we own. I'm sure MB will be no different.
Just going by their website :dk: which may be out of date of course??
:doh:
The ELM327 interface came today .
It was very easy to pair to my phone and , using the free software , ran a basic diagnostic throwing up P0102 - MAF low input and P0660 - Intake manifold tuning valve control circuit
That was about all I could do with the free software , so I then upgraded to the paid for version . This allowed me to clear the fault codes , which I did . At this point the engine management light went out and I took the car for a run to confirm it was back to normal .
After returning home , I ran a further diagnostic which showed no fault codes .
At the moment it is too early to tell whether the problem was persisting after replacement of the MAF only because the codes hadn't been cleared - but I'll see how it goes over the next day or two . Currently running the cheap aftermarket MAF , which may or may not prove OK .
The paid version of Torque gives very basic info on my w202 C250TD 1997 model. Revs are the only thing accurate, temp goes to maximum reading and doesnt read fuel trim, mpg or anything like that
Anyone know any ODB reader that will work on the w202
What platform are you using to display data (iOS, Android, other?)
For vehicles that are OBD equipped the are many options - ELM 327, STN1110, Bluetooth, WiFi, wired and prices range from a few pounds to hundreds. There are firms that specialise in this topic such as Autel UK, OBD Solutions, Scantool Direct, iCarsoft and Outils OBD Facile; it may help to look at their sites and/or quiz them gently. There are also loads of items on ebay and Amazon - some (many?) of dubious quality!
Regards, lim
you have OBD on a 1997 W202? Thats the only one I have every seen.
My version shows pressures, temps etc etc on my 211 - but no fault codes (check engine light isnt on) - but I know there are some stored (injector #4 is poorly) - free version of Torque on android phone. Any tips?
As an update to this , since initially resetting the fault codes the aftermarket MAF has given no further trouble ( although there was a fault code there from the original one ) .
Unfortunately , the P0660 code returns every second or third day , with the car dropping back into limp mode . I presume this is the much discussed swirl flap problem .
Since the car remains mobile , albeit with a loss of performance , and the fault is easily reset , I will soldier on with it until the Christmas holidays when I can work on it .
I've read the various threads on this and other fora about removing the flaps and plugging the holes ( and can do this during the holidays if need be ) , but speaking to DRUK on the phone the other night , he suggested cleaning everything up and putting them back in again . I still need to look on EPC and see if the flaps etc can be bought separately from the manifold , as I know the whole assembly is £££ . Since I'd be doing the job myself I don't mind spending time on it , as opposed to money .
I had the manifold off the W124 E250D when I did the glow plugs and it was straightforward enough ; the 270 engine looks broadly similar .
While I'm about it , I also need to change the thermostat and the block heater , and , if having the manifold off helps , perhaps might be as well to do the glow plugs at the same time ... since all these things are in the same area it kind of makes sense to do them all at once .
No doubt once I get in there I'll find other things that need doing .
If I may interject and ask very basic questions; what are swirl flaps, why would the car need them?
As much as I know is - they exist : they are electrically operated flaps in the inlet manifold which modify the air flow into each cylinder . The motor which operates them has a position feedback which tells the ECU the position of the flaps and , if this is not within set parameters the vehicle goes into 'limp mode' .
Some people have removed the flaps altogether , plugging up the shaft holes left in the manifold , and by connecting a resistor between the 12V feed to the motor and the feedback wire , have fooled the ECU into thinking all is well . The vehicle apparently performs fine without them , or with them locked permanently open .
Someone more knowledgeable may be able to enlighten us further .
As stated the Torque Pro app is well worth the buy!
