Hi , Gove has stated that new IC cars will cease to beproducedsold in the UK at the advertised date.
The car will route you via available chargers.Does anyone know what the average waiting time to allow access to the charging point.Tesla charging points are appear to full every time I have a look at them at M4 East Malmsbury.
But don't underestimate sink / toilet unblocker. The muriatic and sulphuric acid content is insane.
EV to bog unblocker - there's thread creep....
I was once in a data-centre when the ‘fire’ button was accidentally pressed, that armed the Halon system to drop with a 30 sec delay, alarms & lights going full blast.There were also Freon and Halon... the latest fire suppression system does not use gas, instead it suck the air out of the room. I've also seen a datacenre that has a system that sprayed mist - water vapour - apparently you can increase the humidity in the room sufficiently to suppress a fire but without damaging the electronic equipment.
I just picked up a new EQE SUV and it already has a built in map route planner with where to stop for a charge, for how long and what charge you will have on arrival and departure.For those with cars that don't have the same level of tech as the Tesla, there's the A Better Route Planner (ABRP) mobile phone app, that gets real-time battery status data from your car and live info from the network, and plans an optimal route for your EV for the quickest journey with minimal charging stops. ABRP will guide you to the charging points and will also tell you how much juice to put in the battery at each stop. Yes, it's AI taking over the world... but it works.
Dunno about heliocopeters, but certain British jets (Hunter and Lighting being examples) used AVPIN as a fuel for the starter. Nasty, nasty stuff.Don't know it it was a urban myth, but when I was on aircraft carriers the WAFUs would speak of something used as a starter fluid in Wessex and Sea King helicopters that essentially created oxygen when burning. So all you could do was contain the fire until it burnt itself out
That was it - AVPINDunno about heliocopeters, but certain British jets (Hunter and Lighting being examples) used AVPIN as a fuel for the starter. Nasty, nasty stuff.
That stuff is innocuous next to what fighters use in the event of a flame-out. Hydrazine I think it is and what's said of it is if an amount smaller even than a pin head contacts skin. cancer will ensue. Not maybe, but will.Dunno about heliocopeters, but certain British jets (Hunter and Lighting being examples) used AVPIN as a fuel for the starter. Nasty, nasty stuff.
Better not throw a cigarette end down the loo then !Using two differing products in the loo can inadvertently lead to making chorine gas!
Very nasty - corrosive to your lungs!
Be careful!!!!!
Especially after a Curry!Better not throw a cigarette end down the loo then !
