I will look for those at work tommorow but I would say that good alignment garage will have them. If you have idea of doing it by yourself without proper equipment then you going to fail.
I have a proper tracking gauge and would class this job as fairly straight forward.
The camber info is mainly so I can compare it against what I have at the moment. I haven't kerbed it in any way so I'm expecting it to be within recommendaions. If it's not then I'll have to take it from there .
Front:
Camber from -0.5 to -1.1
Caster from 4.8 to 6.0
Total Toe (book says neg toe -0.34' to -0.14') but it will wear in inside with that camber
I would recommend the same numbers but positive toe.
If vehicle carry a lot of weight then I would put some weight while you do alignment. Vito and Sprinter have "funny" suspension setup and you have to look on them individual.
