You may need to make a template off the ground off bit, and weld your own bracket up with a thread screw and wing nut. l not sure if some will let you grind a bracket off their van . (may be a wreck ) . some one used a post support with self tappet screws with success , attached a threaded bolt with stop nuts on either side . no welding
