Vito Dualiner Aux Input
flubber
vito 2011
Hi, ive looked around but cant find an answer hence the post, i have a 2011 116CDi Dualliner, with the standard radio i believe a sound 20 with AUX input, the only problem is the aux input is ridiculously low level compared to the Radio, have tried various amps and bits and pieces but its all a bit messy, does anyone know of any other options?
I think you will find what you need from Comand on line.
My old Audio 20 was the same, not tried it with the NTG 2.5 but expect it to be the same.
You might just find it is costly and you could off load your audio 20 and upgrade it to the NTG 2.5 with all you need built in, just copy your files to the SD card.
Look on ebay for NTG 2.5.
The aux in on our sound 20 (socket in the glove box) works fine, it's only basically a 'headphone' connection though so you need to crank up the volume on whatever you're connecting to it (MP3 player).
