vito glow plug/relay prob ?
mickthetap
my 02 vito wont start, the glow plug light comes on when ignition switched on, goes off then comes on permanently, sometimes starts straight away but mostly takes ages, is there a way of telling if its glow plugs or relay thats at fault, if its relay how much and wheres best place to buy.
A CDi should really start without glow plugs at all, but it sounds as if yours needs them on.
To test either unscrew them and test off the battery or use a multimeter to check for power and resistance.
how do i test for power/resistance, have got multi meter and should set to ohlms what readings should i expect and where shall i take readings from
Either disconnect the main relay connector and probe there or disconnect each plug and probe.
Set the meter to resistance/continuity, connect -ve to the body/engine and use the +ve to test.
To check for power is similar but the meter set to accept 12v dc.
thanks for info, will get under bonnet today
